showing the joint on an embedment
Afternoon - I have an assembly consisting of components which are to be used in different products. The dimensions will change accordingly of course but the design is basically the same. Each of these products will have a cut sheet. In the product there is an embedment of a panel into concrete. All well and good for the model but the cut sheet CATdrawing shows the embedded part but not the seam where they
intersect. I have tried different fillet view settings on the dwg viewport setting. but get the pretty much the same result. Using the assemble function in the part workbench changes the parts individual dwgs. I am trying to keep the series to a minimal number of dwgs so I wonder is there a way to show the seam at the embedment surface.
