Creating a Points Coordinates Table - Catia R19
How could I create in a drawing a Points Coordinates Table from a CATPart (please, see the picture)?
MZ7DYJ
RE: Creating a Points Coordinates Table - Catia R19
MZ7DYJ
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Fernando
Just make a view of your CATPart, then select all the points to be included and INSERT + DIMENSIONING + DIMENSIONS + COORDINATE DIMENSION TABLE.
Much easier & quicker then other method.
Fernando
CATIA drawing by using the Coordinate Dimension Table (as you suggested) has always 0 value for Z!
How about if you have points in 3 D with different value than 0 on Z?..................
They aren't showed on drawing!
MZ7DYJ
Also, make sure you choose one of the 3D axis systems at the top of the pop-up window.
MZ7DYJ
I've been working on a macro for this exact purpose. We make pipes and similar structures at my job so I put together this macro to speed up things.
It takes points from the 3D, extracts the x, y and z coordinates and makes a table on the drawing. You can use this as a guide and tweek things if needed.
CODE --> CATScript
'**************************************************************************** 'This macro extracts 3D coordinates for points and creates a complete table on CAT drawing. 'with X, Y and Z coordinates. 'Instructions for use: 'Drawing as window 2. 'Select points and run macro, input table headline and letter. 'Table with 3D coordinates will be created in the view "TABLES". 'Created by Per Björk, 2014 '**************************************************************************** Dim coords(2) As Variant Dim letter, tabHeadline as String Dim numberOfPoints, selWin as Integer Dim foundTables as Boolean Sub CATmain() 'selWin = inputBox ("Which window contains the drawing? Ex. 1, 2, 3...") tabHeadline= inputBox("Table headline?") letter = inputBox ("Which letter? Ex. A, B, C...") '************************************************************* dim selection1 as Selection Set selection1 = CATIA.ActiveDocument.selection numberOfPoints = selection1.Count '************************************************************* Set myWin = CATIA.Windows.Item(2) 'activate drawing window myWin.Activate Dim myDoc As DrawingDocument 'define active document and drawing view Set myDoc = CATIA.ActiveDocument Dim mySheet As DrawingSheet Set mySheet = myDoc.Sheets.Activesheet for i = 1 to mySheet.Views.Count 'check if drawing view "TABLES" exists Dim myView as DrawingView set myView = mySheet.Views.Item(i) Dim MyPrefix, MyIdent, MySuffix As CATBSTR 'initate getViewName MyView.GetViewName MyPrefix, MyIdent, MySuffix if MyPrefix = "TABLES" then 'if "TABLES" exists activate view and exit for loop Set myView = mySheet.Views.Item("TABLES") myView.Activate foundTables = TRUE Exit for end if next if foundTables = FALSE then 'if "TABLES" doesn't exist, create and activate it Set myView = mySheet.Views.Add("TABLES") myView.Activate end if 'create the table itself Dim MyTable As DrawingTable Set MyTable = MyView.Tables.Add(100, 100,numberOfPoints + 2 , 4, 7.5, 20) 'add labels MyTable.SetCellString 1, 1, tabHeadline MyTable.SetCellString 2, 1, "POINT" MyTable.SetCellString 2, 2, "X" MyTable.SetCellString 2, 3, "Y" MyTable.SetCellString 2, 4, "Z" MyTable.MergeCells 1, 1, 1, 4 MyTable.SetCellAlignment 1,1, CatTableTopCenter '******************************************************************* For i = 1 To numberOfPoints 'create correct number of rows Set element = selection1.Item(i) Set selPoint = element.Value Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") ' set TheSPAWorkbench Set TheMeasurable = TheSPAWorkbench.GetMeasurable(selPoint) ' set Measurable with reference TheMeasurable.GetPoint coords ' get coordinates from Measurable 'add point name MyTable.SetCellString 2 + i, 1, letter & i xPoint = round(coords(0),1) 'check decimals if int(xPoint) / xPoint = 1 then 'check if integer MyTable.SetCellString 2 + i, 2, xPoint & ",0" 'add ",0" else MyTable.SetCellString 2 + i, 2, round(coords(0), 1) 'else, use 1 decimal end if yPoint = round(coords(1),1) 'same procedure for y and z if int(yPoint) / yPoint = 1 then MyTable.SetCellString 2 + i, 3, yPoint & ",0" else MyTable.SetCellString 2 + i, 3, round(coords(1), 1) end if zPoint = round(coords(2),1) if int(zPoint) / zPoint = 1 then MyTable.SetCellString 2 + i, 4, zPoint & ",0" else MyTable.SetCellString 2 + i, 4, round(coords(2), 1) end if Next MsgBox "Coordinate table created!" & vbNewline & "Points are presented in order of selection." End SubRE: Creating a Points Coordinates Table - Catia R19
MZ7DYJ
