Hiding Listed Expression
Please refer the attached bmp image for the listed expressions.
I need to hide underlined text under the expressions name and want to hide some the expressions which are in rectangle.
This is required, to avoid the confusion to the other users.
I tried but not able to fix this.
regards,
Sundeep P
Nx 7.5.0.32
RE: Hiding Listed Expression
There was no attachment.
But what I suspect that you're looking for is not going to be supported until NX 10.0, that is the ability to hide selected expressions whenever the expression dialog is open.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You should probably try setting up a spreadsheet to control your expressions.
