Re-loading a part file
Is there a way of re-loading an un-saved modified document without closing down CATIA and re-loading everything in session?
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
RE: Re-loading a part file
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Khimani Mohiki
NX8.5
Khimani Mohiki
NX8.5
Fernando
Fernando
SmartTeam has something that will help, but the part has to be saved (checked-in) to the vault first. SmartTeam shows a symbol in the tree when a loaded part is not the latest version, in which case you can use the REPLACE WITH SELECTED REVISION command to load (update) just that one part.
Khimani Mohiki
NX8.5
Khimani Mohiki
NX8.5
