Surface Contact NX 7.5
i have modelled two sheets which are welded together by spot weld my problem is when i apply load the sheets passes through each other which should not be the case and when i use mesh mating condition the surface move together but there is no stress on spot weld.....so help in choosing the right constrain so that sheets do not pass through each other and are pulled by spot weld only...
