Spot weld with specified diameter
I have been trying to spot weld 2 sheets - with weld point in modelling and weld mesh in fem it works fine but i want to give the weld diameter so i have used CWELD connections it works fine with 1 mm diameter but above that it gives this error
*** USER FATAL MESSAGE 7200 (MDG2PAT)
GHA/GHB POINTS LAY OUTSIDE OF PATCH FOR CWELD/CFAST ELEMENT 2400
