In an assembly, vary the length without using expressions
Hello!
In an assembly, is there any way to have the length of an object to vary without using expressions? I would like to just constrain an object to object A and object B and then vary the distance between object A and B and have the middle object change its length. Is it possible?
Any help is much appreciated!
RE: In an assembly, vary the length without using expressions
yes, it more than likely is possible to do what you need, but hard to explain without more info.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
