Geometric nonlinear analysis. Initial deformation
Dear friends,
I'm trying to model a beam with a initial deformation to perform a geometric nonlinear analysis. I know how to perform the nonlinear analysis but not to introduce the initial deformation. Can anyone help me?
Thanks in advance
Thanks in advance
RE: Geometric nonlinear analysis. Initial deformation
There's an automated load pattern option using load pattern type "notional" which applies a user specified percentage of gravity load(s) as a lateral load for purpose of introducing initial deformations or imperfections in the model. Notional loads are required by AISC steel design in the Direct Analysis method.
Another option to model the initial bow deformation it is by introducing a 'strain' load that causes bending in the beam(asign-- frame loads---strain---curvature3axis or curvature2axis....). It should be introduced in a nonlinear load case-1. Then your geometric nonlinear analysis with P Delta (or say,nonlinear load case-2) should start from the end of load case-1.
You can also model the initial bow deformation by introducing a uniform distributed load, causing the same bending...
