double pipe heat exchanger desing and calculations
hi friends, I am going to program a double pipe heat exchanger designer software and I need to every detail on heat transfer and mechanical design considerations.
I've read some on double pipe heat exchanger on net like this double pipe heat exchanger guide but i need a complete source if exists, I would appreciate if you could introduce some sources to me.
thanks in advance.
RE: double pipe heat exchanger desing and calculations
I did the exact same thing for my company, it's a serious undertaking. I used the Wolverine Heat Transfer Databooks:
http://www.wlv.com/products2/databook/db3/DataBook...
They are all available online in PDF form, I couldn't find the links on the site but they're definitely on there for condensing, sensible, boiling etc. All the formulas and everything you need is in there.
