Help on identification on 30000 gallon pressure vessel
Hello
I have been a lurker on this forum for a while. I am in a situation where I moved a 30K gallon NH3 pressure vessel and cannot locate the correct information for a U1A to replace the missing data plate. Tank was usable in old location, but once moved must be correctly identified and up to code.
I have attached a few pictures of various stampings on tank. Tank measures 107.5 dia and roughly 67ft long
Thanks for any help!!
http://files.engineering.com/getfile.aspx?folder=9...
http://files.engineering.com/getfile.aspx?folder=a...
http://files.engineering.com/getfile.aspx?folder=3...
RE: Help on identification on 30000 gallon pressure vessel
Or do you need to re-create a completely missing plate, but have photo's of the old plate?
2nd tough item: figure out which tank this is, of all the ones that this mfr has made.
I really don't see you being able to achieve these two items. The stampings you have photographed do not appear to have any repeated numbers, i.e. mfr's Job#. So even if you figure out the mfr, determining WHICH tank will be impossible. Further, the two items sticking out of the manway cover appear to be 'hillbilly' engineering*. Tells me a fair ammount about the previous history of this tank. This tank would make an excellent tornado shelter, and not much else.
*IF you get past items 1 & 2, throw that M/W cover away. Welds on NH3 tanks require PWHT 'for process', in addition to welds on an ASME item that thick.
As you've been doing, you need to dig up any/all stamping on the vessel, and hope you can somehow trace these back to some paper documentation.
I couldn't open the first two linked files, but if this is a very old tank, all I can say is good luck...
Mike
Is the tank a listed depreciated asset?
When did you buy it?
From who?
If the from who answer is the fabricator you might really have a chance.
If you buy a lot of tanks from the same place over the same period you probably have an unsolvable problem. Maybe not.
SToneCold
Scary
Maybe you just need to let the person responsible for your liability insurance in on this process.
That might bring a full dose of reality to what they are asking.
Plymouth Tube
Be sure and mention the 'hillbilly' nozzle additions into the manway, where they didn't bother to PWHT the welds, leaving a probable cracking issue.
