What is the total allowable undercut in a 4 inch weld
(7) Undercut
(A) For material less than] in. (25 mm) thick, undercut shall not exceed 1/32 in. (1 mm), except that a maximum 1/16 in. (2 mm) is permitted for an accumulated length of 2 in. (50 mm) in any 12 in. (300 mm). For material equal to or greater than 1 in. thick, undercut shall not exceed 1/16 in. (2 mm) for any length of weld.
It was explained to me that if you take a 12 in. weld and cut it into 3 (4 in. sections) that it is acceptable to have up to a 1/2 in. of undercut over a 1/32 in. but not greater than 1/16 in.
SEE LINK BELOW FOR PICTURE OF DESCRIPTION
Link
RE: What is the total allowable undercut in a 4 inch weld
THE PREVIOUS PICTURE CUT OFF PART OF THE DIMENSIONS
Link
Looking at this the wrong way. Unless the weld in question is only 4" long, you are required to evaluate the UC in the worst 12-inch long section. You do not subdivide that weld - you evaluate it based on the worst 1-ft stretch. Under 1-inch thick, there can be 1/32" or less UC for 100% of the length; and only an accumulated total of 2" of UC greater than 1/32" and not exceeding 1/16". For welds shorter than a full 12-inches long, yes I would prorate the allowable length -- 1" total for a 6" weld, 1/2" for a 3" long weld.
