Rotating Disc Transient-Thermal-Structural
I am looking for some help in setting up an analysis as follows:
I have a rotating disc with a thermal load applied to a rectangular area offset to one side of the disc's face, the disc if then radiatively cooled whilst it rotates at a given speed.
I use workbench v14.5 regularly for simpler coupled non moving thermal-structural analysis regularly but this is a little beyond me and I don't have any experience with ADPL programming (yet) which I assume is required?
Many Thanks
Paul
Many Thanks
Paul
RE: Rotating Disc Transient-Thermal-Structural
Rick Fischer
Principal Engineer
Argonne National Laboratory
The loaded rectangle is fixed in space like a brake disc type problem, Should note that the whole assembly is in UHV environment so it can be assumed that radiation is the main heat transfer mechanism.
*afun,deg
pi=acos(-1)
tinc=.01
tyme=10
ninc=tyme/tinc
rpm=1000
omega=2*pi*rpm
hh=2 ! height of rect patch
ww=4 ! width of rect patch
mr=4 ! mean radius of patch
t=1 ! disk thickness
antype,,new
*do,time,tinc,tyme,tinc
bfdele,all,hgen
angle=omega*180/pi*time
csys,1
clocal,101,0,mr,angle,t/2,-angle
nsel,s,loc,z,0
nsel,r,loc,x,-ww/2,ww/2
nsel,r,loc,y,mr-hh/2,mr+hh/2
bf,all,hgen,.....
radiation BC's here
solve
antype,,restart
*enddo
The idea here is to create a local rectangular coordinate system at the center of your rectangular patch that rotates around the global cylindrical system at your specified speed, and use this to select the nodes in the rectangular patch and apply the heat generation.
Rick Fischer
Principal Engineer
