NX post, Millturn, Caxis
getting seemingly wonky code using supplied "cam_sample_mill_turn.prt" and the included, but slightly modded, "millturn_baxis_5axis" post.
The three last DRILL_METHOD operations post as follows:
N0010 G40 G17 G90
N0020 (Start of X head)
(MILL MILL MILL)
G0 C0.0
G0 X5000 Z400
MT=1303
M321
MT=1403
G0 Y0.0 Z4.175 BA=-90. C-270. S2500 M13
G43 X-1.25 H13
G182 X-.9639 R-1.25 F6.
G180
why only one hole (Should be 4) and why drilling through the part instead of rotating? The post debugger is showing some errors for the other holes, but i have no idea what to do with it's info.
4 axis Millturn post seems to output as expected with a hole at each C rotation
N0010 G40 G17 G94 G90 G70
N0030 G91 G28 Z0.0
:0040 T13 M06
N0050 T14
N0060 G12.1
N0070 G94 G0 G90 X1.25 Y0.0 C90. S2500 M03
N0080 G43 Z4.175 H13
N0090 G82 X.9639 R4.175 F6.
N0100 C0.0
N0110 C270.
N0120 C180.
N0130 G80
N0140 G91 G28 Z0.0
:0150 T14 M06
N0010 G40 G17 G90
(MILL MILL MILL)
G0 C0.0
G0 X5000 Z400
MT=1303
M321
MT=1403
G43 X-1.25 H13
G180
N0030 G91 G28 Z0.0
:0040 T13 M06
N0050 T14
N0060 G12.1
N0100 C0.0
N0110 C270.
N0120 C180.
N0130 G80
N0140 G91 G28 Z0.0
:0150 T14 M06
RE: NX post, Millturn, Caxis
FYI: all 3 files mentioned are out of the box, so it should be easy to replicate this issue; open the part file, post (5ax) and post (4ax). not sure what to show to make it more obvious.
so my question is how to get the 5ax post to output like the 4 axis, for the last drill op in supplied file.
TIA
ideas?
Mark Rief
NX CAM Customer Success
Siemens PLM Software
