Need a REALLY strong injection moldable material
I'm project manager on development of a new fitness product. We have an electronic module embedded inside the fitness product, and we need to protect the electronics from the use/abuse the product experiences in normal use. Basically, the product is a big ball filled with sand, and with a housing inside that holds the embedded electronics. The ball is slammed against walls and floors with as much force as really strong people can apply to it.
Here's a description of the structure, starting with the electronic module at the center of the ball:
The electronic module is surrounded by a cushioning layer of PU foam, and the PU foam is surrounded by a rigid plastic case. (I'm looking for material suggestions for the rigid plastic case.) The plastic case is suspended inside the ball (which is made of really tough TPU). The ball is slightly larger than a basketball.
The ball is filled with a mix of sand and sawdust to make it heavy. The weight of the ball will vary between 8 and 40 pounds depending on the ratio of sand to sawdust that we put into the ball.
We surround the rigid plastic case with a skin of TPU. The TPU skin protects the rigid plastic case from abrasion from the sand. The product needs to survive the force of many thousands of slams. (I'm simplifying the description of the design a bit, but this is the gist of it.)
The product will not be subject to extreme temperatures - it is designed for indoor use. And the product is not intended to be exposed to water or chemicals. It is just intended to be slammed really hard against walls and floors.
We need a material for the rigid plastic case that is very strong. The case will be formed in two parts that need to be joined together with a very strong joint.
My initial thought was glass-filled (or glass-reinforced) nylon or ABS, and then ultrasonically welding the two halves together. However I suspect there may be better choices of materials and/or methods to join the two halves together. I would greatly appreciate any suggestions from members of this forum.
Clint
Clint
RE: Need a REALLY strong injection moldable material
Similar materials are made by others (partially aromatic nylon blends)
Note that glass filled materials are not the easiest to ultrasonic weld.
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
Nice idea to mix two powders to vary the density. Have you heard of magnetite? It's an iron oxide and looks like black sand but twice as dense / heavy. So you could make your ball heavier, or, make it smaller but keep the weight the same.
Chris DeArmitt PhD
President - Phantom Plastics LLC
Consulting, ideas and training on plastic materials
www.phantomplastics.com
Thanks again,
Clint
I'd start with neat nylon and thick-ish walls (2 to 4 mm), sealed with Permatex #2, and held together by screws and captive nuts in external bosses around the periphery for development, and remove the bosses and glue the housing with something more permanent after the design of the electronics is stable.
Polycarbonate is wonderful for impact, but that magical property goes away, completely, in the presence of, and after the presence of, a lot of common chemicals and adhesives. Select your adhesive carefully if you go with PC.
Mike Halloran
Pembroke Pines, FL, USA
By "neat nylon" do you mean nylon with no glass? Just straight nylon?
If we use PC, we would probably use ultrasonic welding or vibration welding to close the case. (Not solvents or glues.)
We have an access point to allow us to recharge the battery.
Nylon has very good impact resistance too but that varies a lot with humidity (low humidity means much lower impact resistance).
Chris DeArmitt PhD
Thanks for the reminder about humidity and impact resistance in nylon.
The impact forces inside this product are unusual. It's not like a hammer strike. It's a pile of sand that compresses very abruptly (in about 0.002 seconds) then decompresses almost as quickly. It's pretty hard to model. We've had to rely on a lot of empirical testing to work out the design details of this product.
Chris DeArmitt PhD
