Sketch problem in NX 7.5
Hi All,
I have a sketch in NX7.5 which keeps over constraining too quickly when I add contraints. I have tested this by adding a completly seperate line with no inferred contraints, the sketch tells me I need 3 contraints. When I try this with another sketch that is working normally the sketch tells me to add 4 contraints, which is what I would expect.
The sketch giving me problems has a few offset curves, could this be the reason for the unexpected behaviour?
Anyone else come across this or have a fix?
Rich
Rich
RE: Sketch problem in NX 7.5
This is a bit difficult to investigate without an example... Can you upload the partfile ( or create one showing the same behavior )
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
I understand about the need to have an example, not sure if I can post one due to intellectual property rights reasons.
From memory, when I created the offset curves it told me I only needed 1 constraint (the offset value) this seemed normal to me. I have tried to create another offset curve but could not find the associative box although I did have the inferred contrains toggle button selected.
Cheers,
Rich
Thanks for your time
Rich
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
