Sub-model optimization
Dear all,
i have a straight forward problem. I made a Submodel in abaqus of the structure so that the supporting brackets are isolated from the original assembly. The sub modeling simulation is carried out perfectly.
After that I wanted to optimize the isolated bracket, therefor I made an optimization Task inside the Sub model. When I try to run the Optimization takes, an error occurs saying " ERROR the results file containing the global model file was not specified" It looks to me like the Sub model file cannot be used for optimization?
if you have any kind of knowledge about that I would very much appreciate your help.
