Multiple Break-out Section View on single view
I am using NX 8.5 i have observed some problem while creating Break-out Section View
I want to create three "Break out" in the same view but there are several edges that appear after creating second Break-out section view
The first "break out" it's OK.
I create the second "break out" and I get it some edges in my first Breakout section View.
If I create a single "break out", I have the same problem
Following is the attached image
Require help
Thanks in advance
RE: Multiple Break-out Section View on single view
Without having your actual model all that I could do was to attempt to create something similar, albeit much simpler since there was not enough detail visible in your image to get all the nuances of your model, and the results are shown below, at least for the TWO Break-Out view case.
As you can see I had no problems whatsoever. Note that I'm was using NX 8.5.3.3.
If you can't post your model here on a public site, then may I suggest that you contact GTAC and have them look at it.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
