Shims under a tall vertical vessel
I have a 180 foot stack, with total vertical load of 350 kips. There is a 10 inch grout circle around the anchor bolts and the vessel is 15 feet in diameter. My question is how to design the shim plates to level it. Do I put them midspan of the bolts or on each side of the bolt?
RE: Shims under a tall vertical vessel
BA
What are your seismic and wind (hurricane) limits/requirements?
If I located them, I'd probably put them near the anchor bolts.
