Why is SW 2014 taking so long to process Wrap command ???????????
Machine: Windows 7 Pro 3.5 GHZ i& quad core 16GB ram 2GB Quaddro K2000D video card
I have a simple sketch of lines, maybe 40 or 50 little lines, making 6 enclosed areas
Use sketch pattern to make 10 x 2 wide pattern.
Use Wrap to try and put on a simple curved extruded surface.
It takes like 2 minutes before the preview display comes up, then when I hit the
green check mark to execute, it will sit and churn for 40 minutes !!! before it completes.
Does this sound normal to anyone????
RE: Why is SW 2014 taking so long to process Wrap command ???????????
Try reducing the line qty. Try making them a block.
Is the file on a server? Maybe your connection?
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
