zig zag broken dimension
Is it possible to show a broken dimension without a broken view? I want to show a dimension relative to the floor. I wanted to just sketch a line for the floor then edit a dimension and show the dim line with a break.
Certified SolidWorks Associate
SW2009 X64 SP4.1
Dell Precision T3600
Nvidia Quadro 4000
Xeon 3.2GHz Quad Core, 8GB RAM
Win 7 Pro X64
RE: zig zag broken dimension
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
Link
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
Was hoping there was something like this in SW.
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%2020...
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
see att. picture
http://files.engineering.com/getfile.aspx?folder=9...
http://files.engineering.com/getfile.aspx?folder=5...
foreshorten.png on web site
Wayne Matus Nov 8, 2008 12:09 AM (in response to Kim Krubsack)
Here is a work-around if the zigzag is acceptable. You can sketch an arc in the detail view. Add a radiius dimension and a dimension from your edge to the arc centerpoint. You then make the radius dimension a foreshortened dimesnion. You can put the arc on a hidden layer, hide the radius dimension and hide the appropriate dimension and witness lines. This was done in 2009. I could not get the double arrows even though I have it set in the document options.
Thanks again.
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
Thanks again.
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
