Supress Assembly Features per Assembly Arramgements
I have an assembly that has 20 different arrangements. I want to do some sketching in the default arrangement of the main assembly. But I do not want this sketch to show up in the other arrangements. One solution is to use layers. But My question is it possible to suppress a sketch that was created in the assembly per assembly arrangement instead of using layers.
RE: Supress Assembly Features per Assembly Arramgements
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
However, if we're talking about controlling the visibility of the sketch on a per view as well as a per arrangement scheme, than you may have to revert to using a layer-based approach since that can be applied on a per-drawing view basis whereas the Suppression of a feature will be an all or nothing proposition.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
