Coupling CS flange with super SS ring joint / Galvanic corrosion likelihood
3
Dear All,
Can anyone inform if galvanic corrosion could take place when coupling CS RTJ Flanges with super austenitic SS (904 L) ring joints in sea water environment ?
RE: Coupling CS flange with super SS ring joint / Galvanic corrosion likelihood
Yes, and the corrosion of the CS is all that will keep the 904L from corroding.
It is not a seawater suitable alloy.
Plymouth Tube
