Lateral force
Lateral force
Lateral force
After getting the earthquake force(E)of a building by solving the base shear using UBC 1997 seismic code, is the earthquake forces (E) be the value to be used in the load combination 1.2D + 1.0L + 1.0E. I want to learn how to manually analyze frame having vertical loads and lateral loads before learning any structural softwares. Any reference or samples you could share, thanks
RE: Lateral force
yes
Faith is taking the first step even when you can't see the whole staircase. -MLK
RE: Lateral force
thanks, follow up question am i going to solve separately the combination 1.2D+1.0L using say moment distribution and 1.0E using either portal or cantilever method then add up the axial, shear and moments?
