Datums call out @ part center is correct?
Please see attached image. Can i use part center to call out datums?
Please help me to understand, why i can use it.
Darsh
Darsh
RE: Datums call out @ part center is correct?
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
Yes you can have a datum derived from some defined feature (such as part overall dimension) which is effectively the center plane of that feature.
thread1103-292841: Centerlines as Datums and plenty of others http://www.eng-tips.com/search.cfm?pid=1103&ac... touch on this.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
No, you can't use a part centerline to define a datum as shown in your examples. The datum feature symbol must be associated with a particular feature, or features.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
The first response in the thread I linked had this illustration: http://files.engineering.com/getfile.aspx?folder=0...
John-Paul Belanger
Geometric Learning Systems
Paul
You sure will ask why I can't use the center line as a datum feature, here is the answer for you. Even ISO GPS not allow the datum symbol place on the center line on the new standard.
http://www.youtube.com/watch?v=xbA4FrZnZVM
From the point of view on datum point (0.0,0.0) on your last post, use the hole pattern as a datum feature is a good practice as mentioned by Paul.
Season
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
