Beginner: How to export data tables
I want to be honest, I am an absolute beginner with working with SolidEdge but have had a request presented to me to create a program that exports the information in a BOM table to a spreadsheet. Can someone point me to anything that will help me with the APIs required to:
A. Find a data table in a drawing file.
B. Read the data.
I realize this is probably a simple request, but when you're starting at zero that makes it difficult. I have the SDK and the programmer's guide, which has some excellent samples for various things, but doesn't seem to have anything to guide me to the various interfaces I am actually needing.
RE: Beginner: How to export data tables
There are several sources for API/programming help with Solid Edge.
The main one is the Solid Edge Developer Community here that contains a BLOG, Discussion Group, and Knowledge Base: http://community.plm.automation.siemens.com/t5/Sol...
Also, there are many samples located here: http://solidedgesamples.codeplex.com/
Also, in your SE install path there is a Custom folder that has a few samples in it.
Ken G.
http://grundey.blogspot.com
Have you checked out the Solid Edge Community site?
