Part number in BOM
Part number in BOM
Part number in BOM
Hello all,
I need to create a Bill of materials for an assembly drawing.
I tried following:-
Drafting-->Table-->Part list
But here i only get PC no - Part name - Qty.
How can i get the part number column.
Also where do i need to add the part numbers while creating the parts.
regards,
Sundeep P.
Nx 7.5.0.32
RE: Part number in BOM
First you have to define your attributes in every part file. It would be good, if you define File Properties/Attributes in part template file, so that the attribute have the same name in each new part file.
In drawung, when you place the default parts list, you have to insert new columns. For every new column, you Will now define, which attribute you want to show.
When the parts list is finally created, you can save it as your new template parts list.
I have uploaded two movies. In 'kosovnica.avi' you can see, how the parts list is created. In 'kosovnica-template.avi' you can see, how you can store your parts list as template.
If you can not see the movies, let me know and I will upload a codec for those movies..
Thank you SvenBom for the explanation , i was able to view the video files.
regards,
Sundeep P.
Nx 7.5.0.32
