How to "replace component" in a multi model drawing ?
Hi there,
I'am creating a 24" device starting from an already existing 12"
I did a clone assembly for that but forgot some drawings.
I'am now mixing files and replace component, everything is fine until this.
I'am having a drawing file with 2 models (Master model concept) :
- 1 sheet for the welding definition and position of the different pieces using part A
- 1 sheet for the machining operations after welding using part B
I'am able to "replace component" B. Icon is like a normal component.
I can't do the same for A.
The MB3 menu show very few options and the icon is a drawing with 3grey tetris block on it.
How to replace it ?
See screenshot.
How to replace it ?
See screenshot.
"My english is bad ? That's why i'am french."
RE: How to "replace component" in a multi model drawing ?
www.nxjournaling.com
But it's the kind of work i'd like not to do.
I'll do a dummy clone assembly on the 12" to get it using the 24" part numbers and replace the file is the folder.
Yes that's cheating.
Let's call it "working smarter, not harder".
