Abaqus - XY data extraction for shell element
Hello all,
I have tried extracting a stress value at a certain co-ordinate for an equivalent 3d model. I created a path of only 1 node and extracted the von mises stress there. It worked well.
However, when I try the same for a shell model, the software says that 'no results could be found for XY data extraction from the path' (please see pic attached)
Could anyone help me on this matter ?
much appreciated.
http://postimg.org/image/syjlvfuyt/full/
much appreciated.
RE: Abaqus - XY data extraction for shell element
I should have mentioned this before, I am trying to extract the stress values at a certain co-ordinate. It is not at a node. Essentially, this co-ordinate could be in the middle of an element.
Thanks a lot,
