Catia R19 - Bracket
5
Catia R19 - Bracket
RE: Catia R19 - Bracket
Thanks Ferdo,
I'd like to create a full parameterized Bracket, using no faces from the original Bracket.
The one that has been attached is just for reference.
Imagine that you go to an interview tube-test and get the Bracket attached as a reference.
You need to create your using the one given only as a visual model……….
MZ7DYJ
So, think that you have a picture or of the model and want to create it.
MZ7DYJ
Has somebody created this part so far?.......
MZ7DYJ
Yes Ferdinand,
I want to use Part Design only.......
MZ7DYJ
I did not see the model as I can not download on my workstation.
Here is the questions and points you shoud know before modelling
1) Get the DATUM-1 DATUM-2 DATUM-3 from the bracket and start desinging from them.
2) You must understand the whole purpose of bracket. To set up you model structure
3) You blank development shoud be simple anf be able to fit the standatd sheets available in the market
and many more......
If you do not have sheetmetal license, get the middle surface generated and thick and go from there.
var
Hi appvid,
I do not have any problem in creating a new part using the old one!
I was interested in building the new bracket, from scratch, using Part Design only.
MZ7DYJ
appvid,
How could I get the "middle surface generated"?
Where is it? GSD?
I am kind of new in Catia.......
MZ7DYJ
There is no such option in catia
when i say middle, I ment nutral axis. sorry for confusion (see this pic. ). this is imaginary line for calculations
This is just an idea how earlier genaration used to do on boards with drafters. Because you do not have sheetmetal license, this approach gives you a chance to calculate whole balmk developement.
var
appvid ,
There is an option like that (middle surface generated) in NX.
That's way I thought that Catia may have it as well.........
MZ7DYJ
D'oh!, you said in 19. that's in 22. and I don't see how to edit a post.
No, it is 19!
MZ7DYJ
I'll have one in 19 shortly built the same way.
OK Ferdinand.........
I got the picture.
Very useful reply, thanks a lot.
I should have told you that the Bracket shouldn’t be 100% accurate.....
Your input is great, as always…….( NX este specialitatea mea).
MZ7DYJ
Ferdinand, another info...
I have to admit that I try to avoid GSD. That;s because I can't handle this tfeature good enough......
MZ7DYJ
I can't open it!.........
Can you resend it for me, please?
MZ7DYJ
Am s-o deschid acasa...e timpul sa plec. Tu nu dormi, inca?
MZ7DYJ
Thanks begnor ,
You have very good skils!
Thanks Ferdo, I've learned something else today from you!
MZ7DYJ
You can create a very high-fidelity model of this part using 2D/3D curves and surfaces in CATIA V5 with GSD. In fact, this is the way formed sheet metal brackets were modeled back when we used good old CATIA V4. The images posted by ferdo show just how difficult it can be to create an accurate wireframe and surface definition of a complex formed sheet metal part. Even the last (yellow) image he posted of the bracket did not look like it was a 100% accurate representation of how the formed sheet metal bracket would appear. But like I said, it is not easy to accurately model this type of part.
Thanks Tbuelna!
MZ7DYJ
evereux:
Thanks a lot!
MZ7DYJ
