Elevator Shaft
Elevator Shaft
Where is the best location for concrete elevator shaft to place so as not to compromise the building's resistance against torsional moments due to eccentricities, say a building plan with a width of 10m(2@5m) and length of 16m(4@4m)
RE: Elevator Shaft
RE: Elevator Shaft
RE: Elevator Shaft
RE: Elevator Shaft
RE: Elevator Shaft
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
RE: Elevator Shaft
RE: Elevator Shaft
RE: Elevator Shaft
Faith is taking the first step even when you can't see the whole staircase. -MLK
