PLC as an astronomical time clock
Does anyone have any suggestions on sources/reference matls for implementing an astronomical timeclock using a PLC. I have the PLC and numerous 480 volt lighting circuits.
RE: PLC as an astronomical time clock
The only suggestion I would have is to use the switch contacts on a mechanical astronomical timeclock as inputs to the PLC. The mechanical time clock is relatively inexpensive and the PLC could handle the rest of the logic.
I didn't say it was a great idea.
Good luck.
