NX 8 user with NX9 Questions about Patterns / Instances / Arrays
Continuing a discussion started in this thread.
So, picking up where I left off, there have been improvements and changes in NX9 regarding associative circular copying. Improvements in Pattern Feature and the addition of Pattern Geometry.
Can you open the attached NX file below (teeth_nx8.prt) in NX9 and unsuppress Edge Blend(5) and see if it is applied correctly? If not try deleting it and reapplying it using the same values?
Why does the second file below work (teeth2_nx8.prt)?
Regarding Pattern Geometry, can one still instance a solid associatively (like in my repetitive "pie section" examples)?
Thanks in advance!
teeth_nx8.prt
teeth2_nx8.prt
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Thanks in advance!
teeth_nx8.prt
teeth2_nx8.prt
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
RE: NX 8 user with NX9 Questions about Patterns / Instances / Arrays
That being said, if I were you, I would take your original part and contact GTAC and see what they've got to say about it (warning your that they might come back and recommend using 'Pattern Face' like it did).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I already looked into the What's New for NX9 concerning the Pattern Geometry capability - sounds like it does the same thing as Instance Geometry with a revamped dialog/input criteria, so I should be able to stick to the "pie section" workflow as a last resort.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sent in both parts to GTAC and explained the behavior in NX8, NX9 and NX10. Walter opened in an upcoming MR for NX9 and he said that all the Edge Blends displayed properly. IR was closed as fixed in next release.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
