NXOpen: Exception when accessing RootComponent of a partially loaded Assembly
we are trying to analyze a loaded assembly and provide all contained parts and subassemblies to an external tool via NXOpen.
Currently we are using NX9.
Normally this works perfectly using the GetChildren() method from the RootComponent of a given part.
Something like:
Apparently this is not always the case especially when using the "load partially"-Option.
In some assemblies (but not in all!) I get the following Exception (in german ...) when trying to access the RootComponent:
Question 1: Does anybody have any experience with this behaviour?
Question 2: Is there another way to get the children of a partially loaded part (i.e. without accessing the RootComponent)?
Many thanks
JH
Something like:
Dim dispPart As Part = theSession.Parts.Display
Dim c As ComponentAssembly = dispPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
For Each child As Component In comp.GetChildren()
'Do something with child
Next
end if
In my understanding accessing RootComponent should either be Nothing for piece parts or the component of the given part.Apparently this is not always the case especially when using the "load partially"-Option.
NXOpen.NXException: Teil ist nur teilweise geladen bei NXOpen.Assemblies.ComponentAssembly.get_RootComponent() bei NXJournal.Main(String[] args) in C:\Users\horstm\AppData\Local\Temp\NXJournals6424\journal.vb:Zeile 15.Should translate to: Part is only loaded partially.
Many thanks
JH
RE: NXOpen: Exception when accessing RootComponent of a partially loaded Assembly
If Not root Is Nothing Then ...
The problem is that I get an exception on some partially loaded assemblies when accessing RootComponent in that way.
So i need to have an alternative (if any exists that is).
