COVERTING ORAPHAN MESH TO GEOMETRY IN ABAQUS
FRIENDS
I am having a 3D teeth structure which is in .stl format with I imported to Abaqus(for your information there is an option in the plugins>tools). Now i need to extract the geometry from this mesh.This 32 teeth if i edit it using mesh>edit tools>element>delete, i can't select the single tooth and delete. Some part of a tooth remains even after deleting.Can any suggest me a good option to work on this.After that only I can do partition to root of the teeth and other.
I tried mesh Lab and Free cad since the facets are around 231664 its not working on these.
I am stuck with my project.Can any one help
I am attaching a image of the model also
ANOOP
