Freestyle - Shape modification
I have recently started a new job back on V5 R18, the last time I used V5 at JLR in the Freestyle workbench I could perform 'Shape modification' operations (such as control points, match surface, and extend) on surfaces and splines and it would directly modify the element. Now when I use any of those commands it generates a new surface and hide the original, not really practical when you might be making many, many modifications to a surface or spline when surfacing.
Does anybody know why this might be happening, I presume its a license or settings issue?
Khimani
Khimani
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
RE: Freestyle - Shape modification
Khimani Mohiki
NX8.5
If the surface is created in freeform workbench- then any modification done to surface will be accepeted. No extra surface created
If surface is generated in GSD-then freeform converts that surface before accepting any modification. So new surface gets created.. (see convert wizard documentation)
regards
var
Retaining the history of is exactly the opposite of what I want to do, I want to directly edit the surface and retain no history at all.
Khimani Mohiki
NX8.5
