How to Create dimensions at some orientation in drafting
RE: How to Create dimensions at some orientation in drafting
Won't that make it the default for all dimensions after doing so? If it's a single dimension, I would create a vertical dimension, then before placing the dimension, right click (mouse button 3 or MB3) and select Style and then change the F value as suggested above.
Looks like a GM Powertrain drawing and you wouldn't want that as your default dimension setting if that is the case.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
mmauldin,
Thanks, it is working for horizontal and vertical dimensions, But not for diameter dimensions. For the one I am looking orient. Is there a way to orient that also?
Srikanth
I'm betting those dimensions you are seeing are not Diametric, but Vertical or Parallel dimensions with prepended Ø symbols.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
