decipher this german circuit
http://patentscope.wipo.int/search/en/WO2006015713
What does the circuit in the above link do? We've been asked by a client to look into using this to combine power sources with different voltages into a "halfway voltage" power supply. E.g. Input 5V and 3V supply and out the other side comes a 4V supply. I can't make heads or tails of the circuit in the link. Simulations aren't matching up to what the breadboard proto does either; I can provide more details if anybody is curious, but neither supports a the requested use case. Any ideas?
RE: decipher this german circuit
Ah ok. Thanks. How would it buffer the voltage value of the resistor divider across to the output? I can't visualize how that would happen unless the FETs were operating in their linear regions, but that would be no good for a power source, no? To me, it looks like either the top rail being passed or the bottom rail being passed with a dead zone from -Vfet_threshold to + Vfet_threshold. Is that not the case?
No, they're source followers, so they'll follow, with a FET threshold drop, the voltage at the tap in the resistor divider. If this is what you want to do, the LH0063 would probably be a better choice, since it's got something like 98% gain, which is better than the circuit in the patent, and it'll supply a reasonably amount of current. http://www.datasheetarchive.com/dl/Scans-063/DSA2I... the original National Semi datasheet. ~1/4 amp from the LH0063.
Alternately, if you want to buffer the voltage divider, a simple power op amp circuit would be less of a bother, since its gain would be in the 99.9% range.
TTFN
Got it now. Thanks!
A patent on a complementary source-follower charging a couple of caps?
Wow... just wow...
Apart from that, if the FETs are depletion-mode types, the circuit will work. But those are scarce nowadays.
Benta.
As a native German speaker I'd like to shed some light into the topic:
on the circuit itslef:
This is not a circuit for signal processing but for power. In power elctronics e.g in Inverters connected to 400 V three-phase mains, electrolytic caps have to be connectec in series due to their Limitation in voltage rating. To balance the voltage parallel resistors have to be added, creating significant no-load losses. The circuit ensures proper voltage sharing with much lower losses.
On patent law in the ROW (Rest of world, not US): The document attached is an international patent application, not a granted patent. According to depatisnet - an internet service of the german patent office - no national patent related to this application was granted anywhere.
