A615 vs A996
A615 vs A996
I'm working on a project where the contractor would like to use ASTM A996 rebar in lieu of A615. I'm not familiar at all with A996. Are there any pluses/minuses between the two? Can A996 grade 60 be substituted straight for A615 grade 60? Why isn't A996 in greater use? Is there any real reason to reject A996?
thanks.
thanks.
RE: A615 vs A996
RE: A615 vs A996
As I said, there is only one producer of A996 that we know of, and they consume most of the north American railroad axles. Rail axles are a tightly graded steel so quality is well controlled. There is no reason to exclude A996 axe steel from your projects.
I do not think anyone is making rail steel in the US, and it is not an acceptable substitute for most uses.
John Turner CSP PE
CRSI Greater Southwestern Regional Manager
RE: A615 vs A996
I was especially wondering why it wasn't just graded A615, but that answer makes sense.
