Display sheet name in annotation
Hi All,
I want to reference in an annotation the drawing sheet name using attributes. The attribute will be written into a master model part template. I have tried using object attributes but with no success. Can someone help? The referenced sheet name will be used as sheet number as the inbuilt sheet_number function is not applicable in our environment.
Thanks in advance
Thanks in advance
RE: Display sheet name in annotation
The same probably works with other versions of NX, post back with your version information if it doesn't work for you.
www.nxjournaling.com
