Stress by percent (%) - color problem in EXP mode
I'm struggling with something weired in CAESAR II:
Here in this first image you can see de Stress by Percent (%)
If you take a closer look at the bottom there is are 2 nodes (210 and 220) that distance from eachother 500mm. The Displacementes at node 220 were all specified as zero. The colors in this case seem to be good.
In this second imagen, the only change that i've made was the 220. Instead of gooing straight, i move it to the Y axis with a 800mm length distance from node 210. Displacements maintained all at zero.
As you can see in this case the colors aren't showed properly. you may confirm this with the values form the following image related to this 2nd case.
Any ideas for what may be causing this??
RE: Stress by percent (%) - color problem in EXP mode
Sorry mate but there are no images!!!!
Hi there,
Anyone have any ideas that can help me?
These JPG images render as a blank page? We need to look into this in detail. Please open an SR (Support Request) on Intergraph's Smart Support page. Include the job file, your images, and detailed information regarding the exact version and build of the software you are using.
Richard Ay
Intergraph CAS
If possible can you pls upload both caesar ii files so that members can have a look into the problem and try to get some solution for you...
