Change value of expression with a journal
Hello together,
how could I change the value of an expression of a part which is in an assembly?
Assembly
|>Part in which I would like to change the value
Value: 1 (Integer)
Thank you very much
Goof
Assembly
Value: 1 (Integer)
Thank you very much
Goof
RE: Change value of expression with a journal
General strategy:
www.nxjournaling.com
Thank you Goof
CODE -->
Option Strict Off Imports System Imports NXOpen Module NXJournal Sub Main (ByVal args() As String) Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Make Work Part") Dim component1 As Assemblies.Component = CType(workPart.ComponentAssembly.RootComponent.FindObject("Part_Where_the_expression_is"), Assemblies.Component) Dim partLoadStatus1 As PartLoadStatus theSession.Parts.SetWorkComponent(component1, partLoadStatus1) workPart = theSession.Parts.Work partLoadStatus1.Dispose() theSession.SetUndoMarkName(markId1, "Make Work Part") Dim markId2 As Session.UndoMarkId markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Expression") Dim expression1 As Expression = CType(workPart.Expressions.FindObject("TYPAUSWAHL"), Expression) Dim nullUnit As Unit = Nothing Dim oValue as String =Inputbox("Number") 'workPart.Expressions.EditWithUnits(expression1, nullUnit, "2") workPart.Expressions.EditWithUnits(expression1, nullUnit, oValue) Dim markId3 As Session.UndoMarkId markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Update Expression Data") Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.DoUpdate(markId3) theSession.DeleteUndoMark(markId3, "Update Expression Data") Dim markId4 As Session.UndoMarkId markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Update Expression Data") Dim nErrs2 As Integer nErrs2 = theSession.UpdateManager.DoUpdate(markId4) theSession.DeleteUndoMark(markId4, "Update Expression Data") Dim markId5 As Session.UndoMarkId markId5 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Make Work Part") Dim nullAssemblies_Component As Assemblies.Component = Nothing Dim partLoadStatus2 As PartLoadStatus theSession.Parts.SetWorkComponent(nullAssemblies_Component, partLoadStatus2) workPart = theSession.Parts.Work partLoadStatus2.Dispose() theSession.SetUndoMarkName(markId5, "Make Work Part") End Sub End ModuleRE: Change value of expression with a journal
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Dim theSession As Session = Session.GetSession() Dim dispPart As Part = theSession.Parts.Display Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow Sub Main() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If 'lw.SelectDevice(ListingWindow.DeviceType.Window, "") lw.SelectDevice(ListingWindow.DeviceType.None, "") lw.Open() Const undoMarkName As String = "change component expression" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) '***** 'change the following line to the desired component display name Const compName As String = "WIDGET" '***** Dim theComponent As Assemblies.Component = Nothing Try ' TODO: Add your application code here theComponent = FindComponent(compName) If IsNothing(theComponent) Then lw.WriteLine("component not found") 'ask user to select component If SelectComponent("Select a component", theComponent) = Selection.Response.Cancel Then 'user pressed cancel, exit journal Return End If Else lw.WriteLine("component found, tag: " & theComponent.Tag.ToString) End If Catch ex As NXException theSession.UndoToMark(markId1, undoMarkName) MsgBox(ex.Message) Finally End Try lw.WriteLine("component.DisplayName: " & theComponent.DisplayName) MakeWorkPart(theComponent) Dim expToFind As String = "TypeChange" Try Dim myExp As Expression myExp = workPart.Expressions.FindObject(expToFind) lw.WriteLine(myExp.Name) lw.WriteLine(myExp.RightHandSide) myExp.RightHandSide = "1" Catch ex As NXException 'MsgBox(ex.Message) If ex.ErrorCode = 3520016 Then 'no object found with this name 'code to handle this error lw.WriteLine("expression not found with name: " & expToFind) Else 'code to handle other errors lw.WriteLine(ex.ErrorCode & ": " & ex.Message) End If End Try lw.Close() End Sub Function FindComponent(ByVal theName As String) As Assemblies.Component Dim tempComp As Assemblies.Component = Nothing lw.WriteLine("searching: " & dispPart.Leaf) Try Dim c As Assemblies.ComponentAssembly = dispPart.ComponentAssembly If Not IsNothing(c.RootComponent) Then tempComp = SearchComponentChildren(c.RootComponent, theName) Else 'no components Return Nothing End If Catch ex As NXException MsgBox("Error: " & ex.Message) Return Nothing End Try Return tempComp End Function Function SearchComponentChildren(ByVal comp As Assemblies.Component, ByVal theName As String) As Assemblies.Component Dim tempComp As Assemblies.Component lw.WriteLine("searching through components...") For Each child As Assemblies.Component In comp.GetChildren() lw.WriteLine("...processing: " & child.DisplayName) If child.GetChildren.Length <> 0 Then '*** this is a subassembly lw.WriteLine("...this is a subassembly, searching through its components...") tempComp = SearchComponentChildren(child, theName) Else 'this component has no children (it is a leaf node) 'add any code specific to bottom level components If child.DisplayName.ToUpper = theName.ToUpper Then tempComp = child lw.WriteLine("component found, returning: " & tempComp.DisplayName) Return tempComp End If End If Next 'we've run through all the children and didn't find it... Return Nothing End Function Function SelectComponent(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select a component" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_component_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selobj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Sub MakeWorkPart(ByVal theComponent As Assemblies.Component) Dim partLoadStatus1 As PartLoadStatus Try theSession.Parts.SetWorkComponent(theComponent, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus1) workPart = theSession.Parts.Work Catch ex As NXException MsgBox("Error: " & ex.Message) Finally partLoadStatus1.Dispose() End Try End Sub End Modulewww.nxjournaling.com
thank you very much for the code. I try it today.
Goof
