Default suggested naming when exporting as PDF
Hi all,
NX is preset to add the username of the logged in user as a prefix to the suggested name when you perform a PDF output.
I'd like to change remove the username prefix to leave only "filename.pdf"
I can't for the life of me find where. Strangely, it is not in Customer Defaults > Gateway > PDF Export
Would someone point me in the right direction please?
Thanks!
Julian
RE: Default suggested naming when exporting as PDF
Oh hallelujah!
You know, I searched (again) before posting: "PDF naming".
I guess this setting should show up when the defaults are searched (binoculars) by the query "PDF"
Anyways, thanks!
