Lowering temperature below the equilibrium solidification temperature nucleation occurs more readily
In the book science and engineering of William Callister in the pages 315 an 316 at the final paragraph the book says that the critical radius r* and the Gibbs free energy G* are decreasing functions of temperature, the higher the temperature the lower the critical radius r* and the Gibbs free energy G*. After that the book mention a plot that has two profiles of Gibbs free energy G* Vs critical radius r* corresponding of two different temperatures T1 & T2 in which T2>T1, the profile of temperature T1 looks displayed to the right because of r* and G* are greater for lower T1. After this the book says “ lowering the temperature at temperatures below the equilibrium solidifiaction temperature (Tm) nucleation occurs more readily” and I don’t understand and find the connection of this part with the other parts of this parragraph.
RE: Lowering temperature below the equilibrium solidification temperature nucleation occurs more readily
I'm just one step away from being rich, all I need now is money.
( read somewhere on the internet)
It sounds like possibly the figure you are referring to is mislabeled but I cannot see to verify.
