Layer Problem
Layer Problem
Layer Problem
Could someone shed some light on my newest problem
I have an assembly with a component that I am working with and I noticed something strange
I have my layers set up in the part
when I go back to the main assembly and make that part my work part the features that I set the levels on are on different layers
Should the features I put on layers not stay on those layers when you go back to the main assembly?
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Win 7 Pro x64
RE: Layer Problem
Hi Brian.
In the customer defaults Assemblies - general section you can set (in the Component OPerations) which action should be performed when adding components to an assembly.
In here you can state which layer should be used for your components in context of your assembly (Original, Work or As specified)
Original - All layers will remain as being used in the component
Work - All entities in your component will be transfered to the work layer currently set in your assembly
As Specified - you can specify the destination layer for each component layer used.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
RE: Layer Problem
The option that nutace mentioned can also be chosen at the time the component is added to the assembly (Add Component dialog -> Settings -> Layer Option). Or it can be changed after the component is added (Component properties -> Assembly -> General -> Layer Option).
www.nxjournaling.com
RE: Layer Problem
But this is already added, changed the feature layers in the part, go back to assembly, make that work part, look in feature tree and the layers are different
I don't remember this happening in 8.5
NX 9.0.2.5 / PDW
Win 7 Pro x64
RE: Layer Problem
I did the synchronize layers and it fixed all but 1 feature, but I figured out how to fix it
What I did was I set the component that these features are in, from original to layer 1 in the properties
Then I set back to layer original and everything went back to matching up
strange!
Thanks for your help,
NX 9.0.2.5 / PDW
Win 7 Pro x64
