Corrosion monitoring data
We are currently using LPR projecting pobes in our corrosion monitoring program of our oil production field. We however have some problems on assessing the reliability of the data it provides us. We can see some important and sudden increase and decrease of the corrosion rate sometimes that have apparently no link to process matters or chemical treatment. If we look at the voltage info it occurs each time the voltage is falling under the usual 20mV.
The supplier informed us it was due to the presence in ATEX zone so the voltage had to be lowered in order to keep the current in the ATEX limits, however I'd like to have the support from someone external because this happens even when corrosion rate and thus current is pretty low (1mpy - 0.03mA).
Thanks in advance for your support !
RE: Corrosion monitoring data
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Steve Jones
