Fixing ranges in a part using Expression
Hello all,
I need to fix the ranges of a feature in a part using expressions.
Eg: Lets say i have cube of 50x50x50 and i need to have a hole of dia 5 with the position which is within 50 on one of the face, if user enters value less than = 47, its acceptable or else, the system should through error.
Thanks in advance.
Sundeep P.
Nx 7.5.0.32
Thanks in advance.
Sundeep P.
Nx 7.5.0.32
RE: Fixing ranges in a part using Expression
www.nxjournaling.com
But can you please elaborate a bit.
Example: I have generated a cube model (please refer the model & bmp image in zip file - cube), my requirement is, the length should be less than 120mm, if the user enters value more than 120, the system should not accept & it should indicate an error.
I do not use TC.
Sundeep P.
Nx 7.5.0.32
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
