Merge Surface into just one Catia V5
Hello;
I have a geometry composed by hundreds of little surfaces. A closeup in the picture.
All the surfaces are tangent and I want to join them into just one surface. I have tried with the Join and Heal commands, and even tried the "Create Datum" commmand, but still don't manage to achieve my goal.
When I use commands such "Curve on Surface" from the "Freestyle" module, I can just make a line in one of the little surfaces, and not in the joined/healed surface!! Doing one by one is not an option...
Any suggestion??
Thank you very much for your help!!! smile
RE: Merge Surface into just one Catia V5
if you are using R22, you can use the surface simplification command found in the GSD workbench
Mmmmh... thanks, but I am using R20...
have you tried healing AFTER creating the Datum? if it doesn't work, divide your datum surface boundery in 4 and heal these boundery. then try filling the surface.
lastly, try to divide your surface in smaller chunks. maybe to difficult to do that many surfaces at once.
