Modeling Play areas with wood chips that has underdrain
Any idea what would be the initial abstraction for a wood chip play area? I am modeling it with an under drain system. What can would be a good curve number substitute surface to model the wood chips?
RE: Modeling Play areas with wood chips that has underdrain
Obviously, any storage volume within the wood chips themselves would be highly variable based on a current water content, but there should be a constant void ratio within the wood chip bed itself. What that is (50%) I really have no idea. Interesting question.
