ESP
ESP
hi
i have a ques about ESP troubleshooting
if i have low flow how could i know that there is a hole in tubing,,and if i know does its location matter i mean if it is in the joints above pump or in the middle or last joints before well head.and i waana pdf about esp troubleshooting that may help me understanding more.thx
RE: ESP
Just for your future edification, eng-tips.com does not have the limitations of either Twitter or texting. You can write in complete sentences, use appropriate capitalization, and minimize pointless abbreviations. Try to remember that most of the people you are asking for [free] consulting come from an age where a certain level of professionalism was expected from a professional.
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
RE: ESP
I respect your comments on me and sorry for my words,but i really searched alot and found nothing and that pdf or paper or any thing can be my reference just all. appreciate your help.
RE: ESP
You should troubleshoot as you would any regular artificial lift, check tubing/casing pressures and verify they are not equalized. Run the well and check for pressure or a vacuum condition to indicate if fluid is falling downhole past the pump or via a hole above.
RE: ESP
David Simpson, PE
RE: ESP
I was in a troubleshooting job on a well,they said the amp is.constant with no flow, and I found that from there reports that there was flow with the same amp but now no.
I operated the pump and the amp was constant not Dec for an hour but no flow found, I opened chock completely and I also took shut in pressure at well head and it was zero,so I assumed there was hole in tubbing but in the joints above discharge head.
And I was rigth, my point is what if it was in middle or at top joints what are the signs that make me assume the location.
RE: ESP
David Simpson, PE
RE: ESP
RE: ESP
David Simpson, PE
RE: ESP
RE: ESP
David Simpson, PE
RE: ESP
