save pdf line thicknesses the same sworks 2014
I just installed 2014 SP4. I noticed when I save a drg to a pdf, the line thicknesses are the same even though I have thin lines set to .006 and normal set to .015. The section lines are coming out thicker (thick set to .017). Anyone encountered this?
RE: save pdf line thicknesses the same sworks 2014
BTW...I clicked on the Use specified printer line weights in the pdf options. I tried deselecting it, but no luck.
I have not seen this problem. Check your PDF Printer settings.
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
